Hi - This is pet_mich again. Thanks for all the help with the wiring on Unilite Distributor.
(got that hooked up) My problem now is two-fold. When I press my horn button all I hear is a fairly loud buzzing - sounds like it is coming from the horn relay. Both horns work-put 12 v. directly to each one. I took the cover off the horn relay (on the core support and with it still hooked up, if I take my fingers and lift up on that little contact horns blow fine. Bought a new relay from Autozone and relay still makes a buzzing sound and horns do not work. Also the engine does not crank or make a sound. All fuses appear to be good. (Optima red battery,all lights work,radio works, dash lights glow with key on) Dont really know where to start - almost everything on car is new or rebuilt including the tilt column, new 105 amp 1 wire alternator. Am very weak in the electrical department if you cant tell already.
'69 Rally Sport, Small block.
Thanks in advance for any assistance.
pet_mich
pet_mich
