Hi, I have two questions. Hopefully I posted this in the right spot!
1. I am converting to manual steering from power. I have obtained a gearbox and manual pitman arm but my question is about the drag link. I have been told by some that the stud size on pitman arm for power is larger and I would need a drag link off a manual steering car for my conversion. A couple of the big camaro parts suppliers said the drag link is the same for either application. Who is right?
2. I am switching to a big block from small block. Can I use small block frame stands with taller solid motor mounts or do I need the big block frame stands. I have heard both ways.
Thanks,
jj67cam
Thanks,
jj67cam
