Hello guys!
I'm in need of your experience and opinions on this one.
I'm actually refreshing my camaro engine. It's a small block 350 chevy from 1968. It will be near stock, with a small cam upgrade, 4bbl carb, stock intake, no headers. I do not have an unlimited budget, which is already busted a lot. I would just put the higher-end bearings and not care about it if I could...
I would be ordering from summit (or elsewhere if recommended). For the moment, I have came across : King, sealed power, and clevite (which starts to be more expensive...) those brands also have different series... for example, Clevite price range for main bearings goes from 40$ to 260$ for the set! What a difference!
I have also came accross the ''summit'' house brand... which is very inexpensive, and this got me questionning. However, I have heard only good things about the summit house brand; from cams, lifters, to rings, etc...
Even saw some ''engine tech'' bearings from rock auto for lett than 10$ a set...Ishh
I was also wondering, I know that they are selling 0.01, 0.02 and 0.03 oversize bearings for re-grounds journals, but what about the 0.001, they are usually more expensive... and I don't think it's possible to grind only 0.001 from the journal.. or is it??
I would like to hear about your experience with '' inexpensive'' bearings. I know that a lot of people could say: I went with the most expensive, and I had no problems... Yeah...I hope so!
But like i said, I am looking for a quality/price compromise... the best ''bang for the buck'' for a non-performance, non-racing engine which will probably do 500 miles/year
thanks a lot!
g.b.
It depends on what level you are doing your engine. Clevite 77 are usually the premium bearings, better quality, but higher price. I put King and sealed power bearings in my latest build. They looked great to me and have performed perfectly so far. The summit house brand is most likely the same supplier as other major discount parts stores. I figure budget bearings are fine unless you are doing sustained high RPM operation, or really abusing the engine somehow. In the case of racing or boosted/nitrous/high HP applications, I would go for the best available. However, if its a budget build, daily driver street machine, the cheap brands are probably fine.
For how you described your engine, nearly stock, low use, I would simply select sealed power or maybe even consider summit's house brand if they are less expensive. As long as you pay attention to your clearances during assembly, it should be fine.
.001 over bearings are usually for blueprinting your engine. If you were able to polish out the crank journals, but did not need to turn the crank undersize. You or your machinist may have determined that need to run a little bit larger bearings to take up the space to keep your oil pressure up, this is why these .001 bearings are available
I have a same dilemma now.
Which bearings should I buy? I don't want the cheapest ones, but don't want to overpaying either if not necessary. Just want good quality, what will last for long time.
Any more input about these bearings?
Also which material the most realiable? Tri Metal, Copper lead, Silicon Aluminum, TM77 , Duroshield , etc...
Thanks :beers:
You cant go wrong with any of the rebuilder stuff FEDERAL MOGUL MICHIGAN KING The ENGINE TECH are more than likely reboxed FED MOGUL or MICHIGAN . There aren't too many bearing factories. Alex
