What did a chevy small block with casting number 3914669 come in ? what is it ? Thank you.
I can't seem to find that number.
1968 3914660 327 210-300hp 2- bolt
Get the ID stamping also.
Banned
Post back the letters at the end of the long VIN number string that is on the small deck pad above the pass. side top water pump bolt and we will decode it for you.
Nothing there, it's a crap shoot!
pdq67
Had my son look at the block again.Here are the right numbers. Block Casting 3914660 Date E 9-8 Front Pad T05I1HK The guy wants $200 includes everything but the manifold.What is it and is it a good buy.[needs to be rebuilt] Thank You
1968 3914660 327 210-300hp 2- bolt ................ E 9-8 = May 9th 1968
HK 1968 327 250HP 4Bbl Powerglide
Looks like a Low HP (250) 327. a '68 block should be a large journal crankshaft. $200 is not a steal for a core, but not bad.
