1 - 19 of 19 Posts
So my 67 RS/SS is going to be needing an engine. I could use some advice on how to stuff the biggest cubed motor I can afford into this thing, and still keep my SS hood.
I really don't like the cowl hoods, but I'm concerned about clearance issues on the SS one. The problem is, I also want a BIG motor as in 500+ cubes.
So can a big block that large be stuffed in there, w/out putting on a low rise intake/carb combination that will negatively impact the performance of the motor too much? Would a fuel injected BBC fit better? Should I be considering an aftermarket subframe that will allow the motor to sit lower? I'd really rather keep the stock subframe, even if I have to modify it for expense reasons.
I'd appreciate some opinions/options. My only two requirements really are, keep the SS hood, and lots of cubes ;) Oh, and also that I don't have to build it from ground up. I've had to replace many engines in vehicles, but always start with a short block, and don't really think I have the skill to start with a bare block, so I'm considering a crate.
Thanks!
Yes you could put a 502 or it stroked brother the 540 under your hood with a drop base air filter. Pretty sure but not positive you could use a edelbrock rpm or rpm air gap manifold. There is also the stroked 454 a 496 or if sonic tested block bore it out to a 505. If no one with a ss hood chimes in on what will fit you might try a search. There must be a post on this somewhere. mark
I guess first a price range is needed. Any combo based off a 454, 502 or Dart 540 block will fit. What are your goals for the engine? What kind of power?
I guess I really don't want to spend any more than I have to. I was looking at a crate 502 but I think I've seen bigger engines out there for cheaper than the 12k they cost last time I looked a long time ago. Unless the 12k I'm remembering was for the 572ci..... I'm told the 572 is a tall deck block, and no way it would fit under the SS hood so I guess that's out ;)
I'm obviously not very engine smart. I just want something that makes tons of power, big cubes, streetable, dependable, and most importantly, fits under the SS hood w/out sacrificing power. Other than that, I don't care if it's carbed, fuel injected, or whatever. I'm sure anything over 500 ci would easily make at least 500+ HP and that's good enough. Of course 10,000 HP would be great, but I'm not building an airplane :D
I've had several 67 Camaros, but never had a BBC in one. Something you just gotta experience once right? :) Once I can decide on the power plant, I can finish building the rest of the car around that. I'd hate to have to redo the rear, suspension, etc twice if the car ends up with more power than it can handle later.
Thanks for the replies guys.
I'm pretty sure you can go up around 582" with a standard deck height aftermarket block, but I imagine it would be like the 434" small block, like stuffing 10 pounds in a 5 pound bag....
A very common size is a 540"-555" motor with a GM 502 block, there are tons of kits out there for that range.
But really you could go with a 502" which is pretty basic anymore really, and easily make 600 horse and as much torque with pretty basic stuff. That would be the best bang for the buck I think. And it would be a blast to drive :thumbsup: .
I was told once, possibly incorrectly, that with an engine that size I would have to put a short intake on it to fit and that I wouldn't be getting all the performance possible out of the engine. Is that true?
Well it's one of those deals, you can make power at the level you shoot for with any cubic inch. Put a short intake like an RPM or the like on and cam and gear it accordingly and it will still make a ton of power and ridicules torque. Bottom line more cubes will make more power, all else considered. You may not see the peak power etc. with it if you let it breathe but it would be fun....:yes:
Discussion Starter #8 (Edited)
Ok, so how can I go out engine shopping, and be positive what I'm looking at will fit under the hood? What am I looking for? Am I looking for a certain deck height, intake height? Are carbs different heights or pretty much all the same height? etc? I figure most people go out and pick out the engine they want, then worry about how they are going to stuff it in the car, but to me, the SS hood is just one of the things that make the car an SS, and I don't want to be rid of it for a cowl.
Any motor based on a 9.80 deck will fit just like a 396 did I believe. Then after that the big block first gen guys can help with intake selection, but I imagine most high performance dual planes will fit under the hood.
I think the SS hood has a bit more room than a flat hood right? I love the SS hood, I don't blame you for wanting to keep it. Carbs are roughly the same.
Unfortunately my big block experience has been in race cars so I can't help too much on the fitment stuff, but all motors work on about the same principle when it comes down to it.
And besides when your ready for that 800 horse nitrous tune up I can hook you up...... :D
Discussion Starter #10
LOL, let me get the car running and driving first, then we'll worry about the nitrous tuneup :thumbsup:
Speaking of running and driving, I have considered putting a temporary 350 (I have an extra one sitting around) in it just to get it going and then working on saving up for the big motor. But ultimately it will have the BBC, and I need to plan the rest of the drivetrain accordingly to handle that power during the build.
Yes the SS hood has a little more room than a flat hood, but less than a cowl hood. More room can be made by modifying the inner hood structure I've read, but I don't want to do that if it's not necessary.
I’m sort in the same market you are. I've been prepping my car for my next motor for a while now. Currently I have pretty much stock 454 in it and enjoy driving the car while I plan/start my new motor build. I will be building a super charged 540 (Dart block) and my goal is around ~700HP. In order for the car to handle this motor various stock/weak links had to be addressed. My mods so far include:
Cooling system rated up to 750HP
Stage 3 700R4 tranny rated up to 700HP
12 bolt rear end rated up to 800HP
Subframe connectors
Things that are still on my list include:
Fuel delivery system
Driveshaft
Regarding hookup. My goal is not to end up with a drag car by any means so hookup is not that important to me. Having said that I have redone the rear suspension (and front) and the current hookup is awesome compared to the previous one but not ideal for the future 700HP. I just want to be behind a wheel of a 68 camaro that can smoke its tires at 60mph. Something about driving one of those with a huge huffer sticking out of the hood…
582 in a 9.800 block made north of 780 hp with 112 lca cam an idles great for a street car. I've done two of these there great
Good plan! I want to go with one of Mark's 475's (vortecpro on this site ). He has a great reputation and his 475's are a tick under $5K. Plenty of hp for the street :)
500 hp could even be a sbc.
500+ CI with decent cams and heads should be in the mid to high 700's. The larger the displacement the better it will idle with a wild cam.
The longer the stroke the sooner peak power is made. If you are putting a short intake on it you will want a decent cam to make power up high. Since the shorter runners increases torque at higher rpms.
Bore = power. Stroke = torque.
Those engines sounds neat, but the real question is.....
Will it fit under the SS hood?
The simplified answer would be yes... any BBC based on a 9.80 deck height (up to 582" I believe essentially) will fit just like the trusty old 396 did.
So the issue would be keeping the intake low rise enough, which I believe ones like the modern 2 planes from Edelbrock are. Carb will be a personal choice deal, I would recommend a Holley dp, and then a good drop base air cleaner.
Of course the finer details need to be verified by one of our fellow big block Camaro guys, but it should be straight forward with a standard deck height block.
Discussion Starter #17
Thanks Sean for focusing on the main point of my question. It's all about getting the biggest engine to fit. Hopefully someone with a big block and a SS hood will chime in, but they all seem to be MIA. (Or they're all running Cowl hoods).
Christopher,
I can't help you with your BB w/SS hood delimma for your '68 but I'd recommend using a set of Dan Lemons Custom headers for whatever C.I BB you decide to drop into your '68. Dan's headers are designed to fit all of the header tubes inside the frame rails unlike some other headers that require at least one or more header tubes to exit outside of the frame rail. They have excellent ground clearance especially being large tube headers.They are also designed to work with power steeering,etc. I have a set of Dan's headers on my BB '69. Here is the link......................
www.lemonsheaders.com
David F.
1 - 19 of 19 Posts
