1 - 11 of 11 Posts
What are some of your opinions about having a pusher fan on one side of the rad. and a puller fan on the other?
I've heard that the 2 cancel each other out....others say that it would help dramatically!
Any thoughts on this setup?
I currently have a 16" SPAL thin fan and would like to add another as a PUSHER fan on the other side for extra cooling
Thanks.
I have the same fan on an aluminum radiator + zz4 in 69 camaro. With a 180* thermostat, i only exceed 180 while parked. I have the temp control at ON 200* and OFF at 185*. It always operates in that range. The addition of an extra fan would only cool it a little faster when the fan (fans) are ON. And only after reaching the fan control temperature. So, the temperature would not really decrease, it would just cool it a little faster after reaching the sensor ON temperature. Whats your thermostat temperature?
Whats your sensor ON temperature?
Your sensor ON temperature should be at least 15* greater than the thermostat temperature to avoid fan operation while at crusing speeds.
I've heard the same thing.
I am running fans on both sides. What happens to the next round if one fan $hit$ the bed? I would hate to go home early for that reason, I can find plenty of other ways to go out early! :D
Those are some hardcore toys, Smink. I guess your not driving them home anyway, are you? Do you notice any temp difference between a single pull, and the push/pull? Or, are you using a push/pull for reliability?
It may be my imagination but I believe the puller does the better job. Yes they are both installed for the reliability.
I have 2 SPAL they are both PULL and want to reverse the polarity so that the other becomes a PUSH instead. I spoke to SPAL and told me that the blade config would be incorrect... :mad:
Any thoughts??
A 'Pull' fan is stated to be more effienct than a 'pusher' for a couple of reasons.
1. Installing a fan on the front of the radiator actually blocks surface area for cooling.
2. Installing a fan on the rear of the radiator with a shroud actually increases shroud pressurization which increases core efficiency.
3. If using two fans, one on each side, they need to be the same fan with the same CFM rating AND they need to be staggered/offset from each other a not to create a static pressure between the two fans themselves.
SPAL recommends the use of a single 16" Pull fan for HD applications (part# 30102002). The use of their 'Twin" fan with shroud only increases CFM rating by roughly 400 CFM. Depending on on your core dimentions and core efficiency you might consider running a 16" and an AUX 10" to mount on one side. Using the single 10" as a back up or for supplemental cooler.
Blade type is also something to consider. A single strait blade type fan is slightly less efficient as compared to a curved blade.
If you are looking for one fan to do the job, you might want to consider the use of (yeah I know.....) the fan off of the Lincon MKVIII. It is a single, curved blade, two speed fan that pulls over 5000CFM. That is more than everyone else on the market for one single fan. I have been using them in the most severe applications, ie, big block,ac,auto,high stall in Tucson Arizona daytime summer heat......Max effort Desert racing and in max effort quote-un-quote street cars (LOL). and I have found no better. It has a built in shroud and its dimentions are easy on the installation.
Food for thought..........
Hey look at that I found a picture on a friends site: http://soderblom.net/bronco/tech/fan/2.jpg
And another link on electric fans LOADED WITH INFO : http://www.geocities.com/smithmonte/Auto/MarkVIII_Fan.htm
[ 03-10-2003, 11:36 AM: Message edited by: chicane67 ]
Discussion Starter #9
I am currently using a 16" SPAL THINLINE (big block waterpump space limitations) puller right now, it's about 1300CFM, it's about 2" thick overall. It has worked perferctly so far...
I wanted to another to help me with my new build up. I expect it to generate more heat, maybe..?
Yup, you said big block. Now I am understanding your delimma a little better.
I guess a two fan set-up would be the ticket there. As the H20 pump pulley would fit between the two fan motors.
And now looking at the pics on your site, you are core surface limited too.
Discussion Starter #11
No kidding, I guess I'll have to wait and see if the new motor will runner a lot hotter. If that is the case, I may need to go to a dual fan setup. This H2O pump clearance is a PIA! :mad:
1 - 11 of 11 Posts
