The timing is set correct but under w.o.t. it rattles bad, sounds like valve rattle, spark knock or whatever you call it. It's a stock 305. Could it be cheap gas? I'm running 87 octane.
It's in an 86 truck. It's carburated, the dist has a large 4 or 5 prong plug on it. The carb has all those electric plugs in it. I don't know if it has a computer.Patrick - what year and what's it in? Is it computer controled? Carb or fi?
Dang, you might be right! I took off the egr when I swapped intakes. I'll have to put it back on and see if it works! thanks:thumbsup:Is your EGR valve working? I don't think a 86 truck engine has computer comand control {ccc } unless it has Calf. i/m. But it may have an electronic dist with a knock sensor' they called it e.s.c. I think. If the egr valve is not hooked up or not working it will make it ping.
