1 - 2 of 2 Posts
I just put a 327 in the 69 and it was a corvette motor. I have and edelbrock performer intake. My first ? is that I can't remember how to mount the throttle kick down bracket. I have an edelbrock carb also. The bracket was on old motor so should work. (pics would be helpful). The second ? is that I have reinstalled the power steering pump and the secondary bracket that ties to the head does not work on the corvette heads (old heads are off a 305) does any one no the correct bracket. ( again pics would be helpful.
Thanks ahead of time I am sooooooo close.
the original bracket(if i remember correctly)mounts to the manifold and the alve cover bolt.there are aftermarket adjustable brackets that mount on the carb stud also.not sure about the 2nd question.
Eric
1 - 2 of 2 Posts
