1 - 18 of 18 Posts
Hi,
I 'd like to have your advice because i 've never worked on an engine yet (camaro is new for me) and i recently noticed a clicking noise I describe here :
this clicking noise seems like a valve noise, like a valve 'd knock its seal . Or a loose rocker. I don't hear it at idle, or without load. but when we accelerate it comes really, and at cruising too, but not as hard as under full throttle. clicliclcilc come faster with the RPM going faster.
I first heard that noise (very little then) something like 120 miles ago, and the noise increased. Now we hear it more distinctevly than at the begin.
I'd like ou to tell me what you think that noise might be.
I have a Chilton manual. I 'll look in it too see if they talk about tightening rockers and adjusting valves. If you know a web page that explain how to do, tell me please.
And don't i need any special tools for it?
Marc
exhaust leak.. those things can drive a guy insane. make sure your manifolds (or headers) are nice and tight, and that the gasket is good.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see pics here http://community.webshots.com/user/novaderrik
Get a piece of hose about as long as your arm, put one end to your ear, use the other end to search for the sound.
Could be an exhaust leak, rocker that is loose, or noisy fuel pump.
With the fuel pump, the pushrod can get bent if a too-long bolt is EVER put into the right front bolt hole (second hole up from bottom) in the block, the one that intersects the fuel pump pushrod hole. The bent rod can knock.
This hole WILL LEAK OIL, if no bolt is in the hole. A short 3/8" bolt with sealer on it should be in the hole at all times.
The pump has a rubber grommet under the fuel pump diaphragm rod, if it splits, the pump can knock.
David
David's Motorsports page
First Gen Suspension Page
Also could be pinging(sparkknock). Try setting your time a little lower or try a higher octane gas. Does this only when driving?
I came across a similar problem when I had a solid cam in my Firebird. Since it was my first solid lift cam, I thought that the valves needed to be adjusted. No matter how many times I readjusted the valves, the sound would not go away. It turned out to be a leak between my gasket, and the header. My problem was the bolts in the headers. I had 3 different types of bolts, with 3 different lengths! (of all the #$%^%^ reasons) Why the header gaskets would not seal after that particular modification is beyond me. I solved the problem easily by purchasing a set of header bolts. Problem was fixed easily!!! You may want to look into checking all of the exhaust bolts on yourcar.
84 Modified F-body
"Skinnin' season is just a phone call away!"
Thank you !
I'll check all you told me, and i'll let you know. The fact i was a bit long is the car is not home for the while, and i can't drive with it because of a new hood... so no hurry. But we'll fix that clicking problem before we drive it.
It surely isn't a pinging problem, cause we run here with minimum 95 octane, and there is not a lot of advance .
But yes the noise come harder under load.
Thanks,
Marc
you have a car's twin brother it seems. my neighbor tight/adjusted the valve things underneath the valve covers, i don't even know what they are called. that sound is gone. but of course, we know hear the other which i was told is a exhaust leak. seems the donut flunge gasket or something in that area needs some replacing and tightened good. hope this helps
68' 350eng/350trans
88' BMW 735i
Discussion Starter #8
Hi!
Well we checked the rockers at one side, there is not any loose rocker. At the side where the noise come from.
The noise is now VERY hard! even at idle we here it! And we did not ride more than a 60 miles since i told you about it. We can't see a leak from the headers gasket.
Any suggestions?
Marc
Marc, you won't SEE a leak from the headers but it could still be there. make sure all of your exaust manifold bolts are tight at the head. If you find a loose one & the noise gets quieter after tightening but does'nt quite go away, than change the gakets. Other than that the hose ideah to your ear will at least isolate the noisy area, and you can methodically eliminate one possibility after another until the culprit is found. Loose rocker arm, collapsing lifter, rod knocking etc. start with the easiest possible fix & elliminate your potential problems one at a time. A noise described as a clicking sound could be a number of things but by isolating the noisy area, and than eliminating one potential problem after another you will eventually find the cause. Keep us posted, Terry
Discussion Starter #10
Ok thanks.
The problem is i am a novice. And here in BElgium old american V8 are not commun. But i'll try to fix that problem. Anyway i have to. I'll do what you told me about the headers and i'll let you know.
byebye
I had the same symtoms with a brand new 383. Turned out to be a spun #1 rod bearing and the knocking was the piston smacking the head. This is not a good thing for the head. It's not real good on the piston either. It also trashed out the crank and rod. I have had better days. I hope this is not the probem your having. It's not a cheap fix.
Discussion Starter #13
it is the header gasket..
Luckly nothing else!
Discussion Starter #15
Here is how we fixed it for now... I asked the friend i used to work with to come home, he direclty saw the gasket was worn. It was in 3 pieces. So he as he didn't have a new gasket and that it was to bad to leave so he asked for Aluminium paper, and he "rebuild " the gasket with grease on the aluminium paper. He reassembled the whole thing, installed it again on the headers, and the all operation took 30 minutes! Result : the engine runs as new! No clicking noise at all! Of course we will install a set of new gasket soon, but the idea of aluminium was good! My friend also told me to avoid those "paper" gasket and to install full aluminium gasket. What do you think about it?
Marc
D
Guest
I used copper spray with a felpro gasket on my 350. Not sure if that is available there. Hey, I was in Antwerpen about a year ago. Beautiful country.
I had an experience like that and as it turned out it was a rod bearing. They usually get louder under load. Its nice to have an easy fix.
Black 69 camaro
[This message has been edited by HOTROD69CAMARO (edited 05-13-2002).]
Discussion Starter #18
Yes it is nice! Thank you all of you!
1 - 18 of 18 Posts
