Just got a 69 w/350 eng.
It had broken mounts.
I installed new motor mounts
and bolted one side to frame mount
and the other side is about an inch to short to reach
frame mount bolt hole.and the pan almost touches the frame.
what is the difference between BB & SB frame mounts .
any info would be appreciated.
Thanks Daymon
There is more than just small and big block mounts. It sounds like you are using the 67/68 short and wide mounts. You need the 69 tall and narrow mounts. http://www.energysuspension.com shows the difference too. If you bought your new mounts at autozone or somewhere similar... their books are wrong.
lOOKS LIKE YOU ARE RIGHT
i BOUGHT THEM AT aUTOZONE
The ones they sold me were to wide and short.
After researching the great info from you guys,
I need the tall narrow mounts used on 69 350 sb
and 396 bb.
Thanks for the super replys
it helped alot
Daymon
