1 - 2 of 2 Posts
Hi guys
Which motor / frame mounts do I need short and wide or tall and narrow
Currently have short wide mounts and stands but headers hitting
Steering box .its a 67 camaro but has a 69 350 casting no 3970014
The 67 would be the short and wide mounts. You can buy '67 350 engine mounts which are the Anchor part # 2285 and they might help. You can also use the '69 tall and narrow engine mounts along with '69 350 frame mounts. These might help too. By changing the mounts it may just make the problem worse. The problem is usually (but not always) the header that is being used.
1 - 2 of 2 Posts
