Wondering if you guys can give some input before I have to take it to a shop. I decided to take the Camaro to work today since it was a nice day. Anyway, the car ran fine all the way to work. At lunch, I tried cranking it and it tried turning over but it wouldn't stay started. I would pump the gas and it would catch 1 time then die out as soon as I let the key go (any longer and the starter grinded). If I start it with the gas pedal all the way down, I get one big rush then it still dies. I checked that I was getting fuel through the filter and at the carb. I even took off the fuel line, put it in a bottle and cranked it to make sure there was enough gas getting through. I took off the brass fitting the fuel line feeds into and found a bent filter and removed it thinking it was the problem. Still wouldn't catch.
I had it towed home and removed the top of the carb to see if the floats were stuck, but I couldn't find anything wrong. I'm at a stand still, so any advice would be appreciated. By the way, the engine is a 327, 4 speed, edelbrock 600 cfm 4 barrel manual choke carb, air gap intake, and HEI with external coil.
Thanks again. :waving:
