1 - 2 of 2 Posts
Hello all
I have built myself an engine test/run stand and I'm at the point that I want to run a SBC engine with 1987 TPI setup.
My current issue is that I need to find out what wires for the computer must be connect to what power source and what will not be required to just start and run the engine for a few minutes.
The stand does have a radiator and will be using electric cooling fans.I need starter power,fuel pump power, distributor power, oil pressure display and tach.
Any help that you electrical gays can give me will be most appreciated.I'm using a Painless harness that was in my 67 Ragtop at one time
Thanks,
Jerry
By the way, I'm also posting this in the third gen section
1 - 2 of 2 Posts
