So, I need to get some room in my garage for a little bit here and am putting my camaro work on hold for a bit. This leads me to my question...can I put the engine back in the car without the transmission? Will it support it enough with just the engine mounts, or does it need the tranny?
Thanks All
Yes, it will be fine as long as you install the motor mount bolts. Take the cap off the distributor just in case it leans back a little too far, or just wedge a piece of wood between the firewall and engine.
if you leave the distributor in, bolt the engine in the engine mounts and support the oil pan with a couple of 2x4 stacked up.
