Or relay control from PCM not working, relay itself bad, power to the relay for the fan power (fusible link/fuse) not present, or temp sensor for PCM, maybe. If engine fast idles when cold and idles down after warming up, this sensor may not be the problem.
Select either A/C or DEF to see if both fan(s) come on.
