The 350 in my 69 will not crank over very well when hot. I have tried everything I can think of but nothing seems to help. The first thing I did was to have the battery tested and it was fine. I then had the starter tested and the motor was fine but the solenoid was bad under a high temperature test. A new solenoid was put on but that didn't help. The alternator is working ok too. The car turns over just fine when cold but when it gets hot it cranks very slowly and sometimes the solenoid just clicks. If I start it when cold the battery guage on the console swings way over almost to +40 then eventually goes back over just to the right of the zero. Is this normal? Is it possible that my battery may be bad when hot? Any ideas??
Larry W.
1969 Z11 Pace Car
My Pace Car
Larry W.
1969 Z11 Pace Car
My Pace Car
