My fanswill not kick on with the switch they sent. I am using their plug and play harness. My question is can i use a regular temp sending unit to turn these fan on and off?
You can use any switch.
You buy the one that switches at the temperature you want. I use a 90°C switch from a BMW to trigger my fan to low speed. You can test the switch in a pan of water on your stove. Put the thermoswitch in a pan of water cooler than the trigger point and slowly raise the temperature until it triggers.
You can't use a temperature sending unit, as these are meant to drive a gauge.
