Am i naive in thinking i could bolt on the Magnaflow exhaust kits without any mods if i order it? I have a BB but have used the correct mounts so the motor is sitting correctly....and have a Tremec with the custom crossmember......I be stepping down from the collectors to 2.5 pipes and it looks like it will clear, but barely....
From my experience with MagnaFlow, they seem to really do their homework. I have a small block and I got their 2.5" system and it went right on. The only issue I did have was, I had a driveshaft loop and the loop was installed right where the "X" fixture sits so the loop had to go. Other than that, it went right on. I had the system installed BEFORE I went to a TKO-600. The tranny went in with zero issues. The crossmember bolted in and there was no need to modify ANYTHING. Now remember, this is with a small block, but I would expect the big block to be the same, especially since you have the correct mounts and stands.
Please note, that with a big block you need a crossmember that moves the transmission tail, to the passenger side, 1/2 inch and forward 3/4 of an inch. Not all manufactures of crossmembers, will do this. The only way to be sure is to measure what you have ! Don't believe what they say or what they think they know. You will have trouble fitting headers if you do not have this. For the rest of the exhaust, I do not know if the offset will make a difference or not.
Discussion Starter #4 (Edited)
thanks i think im ok on that..the crossmember came with the conversion kit for the TKO specified for a BB...had no issues with the headers (other than a slight dimple for the steering box) or alignment with the driveshaft .....if i were to come straight off the collectors, i would hit the crossmember, but the reducers should make the pipe just miss (i hope)
This is what I am concerned about. You must measure your crossmember. You should not have had to Dimple your headers. You can only measure for the 1/2" offset. The 3/4" is from the small blocks location.
there is always going to be a little fabrication when putting exhaust on the car- no two cars are the same, and there are a lot of different headers out there.
Novaderrik, Headers are not usually the problem. Either somebody changed something from stock or they do not have the correct pieces.
