ok, see if anybody can tell me what this may mean. i put new summit headers and dual 2.5 exhaust system on. with car running , if i put my hand up really close to the exhaust ends, one side makes my hand vibrate a lot more than the other side. both sides cause a steady vibration of your hand, but drivers side is alot more noticeable. it's a 67 with original 327. i have added new summit carb and intake, but have not touched the heads . any ideas? thanks.
Could be a valve adjustment if solids. Bad plug or wire... Check it with a compression gauge to be safe.
skip, thanks man. i didn't know anything about this car, (previous owner knew someone had worked on engine but had no clue of what they did.) i was assuming it hydraulic lifters , but it evidently has solids. put vacuum tester on it and runs steady at 19 now without moving. thanks again !
