After I put my new motor in my tach does not work. I have MSD 6AL with tach output. Car starts and runs perfect and the tach wire is connted to the same place it was before.
How can I test the tach signal? The only other crital is making sure the tach gauge is grounded right?
If I pull the gauges out I want to be able to properly troubleshoot before ordering any new parts.
Was the MSD box with the old engine?
If MSD came with new engine, the OE tach will need an additional filter, I believe.
Of course, only after you check to make sure the tach is grounded correctly.
You could always remove the MSD box and check tach in the original circuit.
The MSD was in the car before. Just looking for what wires are required to make the tach work and how to test the tach signal. If I connect a volt meter and run the engine, what should I see etc.
I belive the tach signal and a ground is all you need. If my tach signal is good, then I will pull the guages and verify ground and tach signal to the guage. Then a new guage if all connections are good no RPM.
How do you test a tach signal.
An oscilloscope would be the best test equipment to use to check a tach signal because its going to be pulsed.
If you have a good DMM, you could use it in AC and view the analog scale at the bottom of the display for the bars running, maybe during starting.
I did connect my DMM and observed 2.xx? volts DC - can't remember exactly. I may be working and I think I will pull the gauges and check for connections and ground Etc.
Thanks to all.
