1 - 8 of 8 Posts
From time to time, over the past couple of years or so, folks have been posting threads on some of the Forums about failed bronze tip fuel pump pushrods. There has of course been some discussion about all that, but no real wind-up as to what is actually going on here.
Since there has not been a solution, some folks have switched to composite fuel pump pushrods in an effort to get out from under this problem. However, that may not be the best choice either, since there have been reports of composite fuel pump pushrods failing, as well as well known failures of composite distributor gears, inside running engines. And that can leave you with quite a task to clean all the broken pieces out of the engine, not to mention having a running failure when you least expect it. So, I don't believe composite engine internal components are a good idea in our traditional SB and BBC's, because failures of that nature indicate an unacceptable margin of safety.
I think it is much better to get to the root cause of what the problem may be with the metallic parts in question. Because bronze fuel pump pushrod tips and bronze distributor gears won't generally ever break on you, in a running engine, even if they may have some wear issues. Bronze parts such as those, are softer material and are expected to wear, thus preventing wear on your steel cam. They are maintenance items, much like solid roller lifters. You can't expect to install them and permanently forget them. At the very least, you should periodically inspect them to see how things are going.
In any case, I think it is about time to do a failure analysis of bronze tip fuel pump pushrods to get to the bottom of the failures some folks are experiencing. To accomplish this, I'm in the process of gathering as much information as I can about this issue.
So, if you'd like to be part of this failure analysis, please share the details about your bronze tip fuel pump pushrod failure, by answering the questions below:
NOTE: Just as important to this overall failure analysis of what did NOT work, is what DID work. So, if you've run a bronze tip fuel pump pushrod, and have had no issue with it, please answer the questions below as well.
1. Did your bronze tip fuel pump pushrod fail on you, or has it been fine?
2. If your bronze tip fuel pump pushrod failed on you, what brand was it?
3. If you experienced a failure, would you consider it excessive wear, or did the bronze tip mushroom to the point that you could not get it out of the block?
4. How many miles did you get out of it, or have gotten out of it so far, if it was primarily a street car?
5.How many passes did you get out of it, or have gotten out of it so far, if it was primarily a drag car?
6. What percentage of the time was this engine operated on the street, and/or what percentage of the time was this engine operated on the track?
7. What rpm did this engine most commonly see?
8. What is the psi rating of the mechanical fuel pump used with this pushrod. The psi is determined by how stiff the diaphragm spring is, which in turn, determines the load applied on the bronze tip.
9. What specific oil or oils, and what viscosity version of that oil or oils, did you use or are using with this pushrod?
10. Did you use any aftermarket oil additives in the oil used with this pushrod?
11. I'd like to get my hands on as many failed pushrods as I can for evaluation. So, would you be willing to send me your failed bronze tip fuel pump pushrod for that purpose? If you really want to keep the pushrod, I'd be happy to return it to you after the evaluation.
12. If you have any additional information on failed composite fuel pump pushrods, please share that as well.
After gathering as much information as possible on the bronze tip pushrods, including physical evaluation of failed parts, I'll post the results of the analysis. And hopefully, we'll have a workable go-forward plan at that time.
Thanks for any information you are willing to share.
540 RAT
Mechanical Engineer
U.S. Patent Holder
Member SAE (Society of Automotive Engineers)
Member ASME (American Society of Mechanical Engineers)
To see my entire 130+ motor oil “Wear Protection Ranking List”, along with additional motor oil tech FACTS (with over 40,000 “views” worldwide), here’s a link:
http://540ratblog.wordpress.com/
I've heard nothing but good things about this pushrod:
http://www.summitracing.com/parts/hrs-94475/overview/
Thoughts?
That's the one I'm using on a steel cam, Don, but only since July 1st of this year. Still pumping fuel! Prior to that I was using the original steel pushrod out of my old 307 for 12,000 miles w/o issue. I only swapped to the composite for peace of mind. Have also been using Comp's composite dist gear for about 10,000 miles. It is showing some wear, but not enough in my opinion to replace it. Stock oil pump.
My engine builder mentioned that he has been using a ceramic tipped fuel pump rod on his circle track engines with good success, but I don't have any info beyond that.
The question is will 540 RAT respond to anything folks post in this thread or will he do his usual post and disappear never addressing the questions provoked by his postings?
I'm still waiting for input on bronze tip fuel pump pushrod failures or successes, which as stated is the whole point of this thread. But, I see that rather than making a meaningful contribution to the discussion, you just want to make snarky little comments. That is not helpful at all.
I rarely post anything on this Forum anymore because I don't typically get much usable info back, just as I'm seeing this time. I keep hoping things will improve, which is why I tried posting this one here. But, when I do post something, it is usually a stand alone deal, where I'm just sharing info. It's an FYI kind of thing. So, there was no overwhelming reason to check back on any discussion that may come out of it. Plus, I don't have a ton of time to sit on the Internet, which is another reason why I usually don't come back to see what is going on with the discussions.
On occasion when I have checked back in, there is probably more arguing than there is questions or an exchange of information. And I simply don't have time for arguing back and forth.
But, I'm still hoping to get some usable information this time around to help with the failure investigation. Though so far, things look a bit disappointing.
540 RAT
However, that may not be the best choice either, since there have been reports of composite fuel pump pushrods failing,..... So, I don't believe composite engine internal components are a good idea in our traditional SB and BBC's, because failures of that nature indicate an unacceptable margin of safety.
Name just about any internal part ever put in a SBC or BBC and I can probably show you a "report" of that part failing. Using that logic we probably shouldn't even start these things.
If you consider a "partially stripped' bronze dist gear breakage there's a thread just below this one that outlines that problem in a 2,000 mile engine http://www.camaros.net/forums/showthread.php?t=294442
Banned
540 RAT
Gosh. That's terrible. Yes, it must take a lot of time flooding all enthusiast forums with the same regurgitated "scientific data" like you are some kinid of expert like you did on your infamous oil threads. Care to explain exactly just who you are and what makes you think we are asking for another "investigation"? Nobody took your oil thread seriously.
I don't agree with DjD often but I do on his post about your behavior.
Thanks Al for the feedback.
1 - 8 of 8 Posts
