I have a 68 Camaro with a 400HP 350 that needs a cooling system upgrade to eliminate high temps. I want to try some simple things first. I do have a high volume water pump and a 185 thermostat.
I have read some articles that say to place the fan between 3/4 and 1" from the radiator, and I have read to place the fan 1/2in and 1/2 out of the shroud. Both are not possible with what I have. If I place it 1/2 and 1/2 it will be several inches from the radiator. The engine is from 1972 so I am not sure if the shroud is correct. Does anybody know the front to rear dimensions on a 68 or 69 shroud? I am planning on installing a new clutch fan, but I want to make sure to get the right amount of spacer.
Thanks for any help you guys can offer!
