Well putting the intake back on..and noticed that the 1205 only had the blue strips around the ports on one side..Well since there was no mention on the packaging..I placed a small bead of Black rtv around some of the ports on the head and laid the gasket down blue side out toward the intake..Someone please tell me I did this right....Thank you
Restored 68 Camaro R/S 327 4 speed
Restored 55 chevy Belair
Blown, Fuel Injected
http://community.webshots.com/user/badcaiman
The gaskets are usually marked UP or TOP for the intake side. A little rtv around the water passages on the heads and blue ridges toward the intake is right. At least that's the way I put mine on 8 years ago.
'69 RS Camaro
355 5-speed 4.11
Discussion Starter · #3 ·
I looked all over the gaskets all I found were some #..no UP or TOP....Wow..I have some luck..I probably got the only gaskets without any markings....Well At the very least I installed it correctly...Thank you
