Is there a special tool needed for the staples that hold the fender well splash gaurd on. Any tips appreciated.
69 Z-11
396
4 SPEED
I use a small drill bit to drill out the necessary holes, insert the staples, and hammer over the ends. It is a little easier if one person holds the staple in place and another hammers them in place. You may want to use a small drift punch to get a better angle on the staple ends.
...Ron
As mentioned, you will need to drill the original holes just a bit larger as the staples that come with your new splash shields are a little thicker. I drilled out the holes and the splash shields together. Insert the new staples and bend the ends over with pliers or any technique you like to get them to look nice and fit snug.
I did the same thing with my A/C baffles. made staples out of stainless wire, drilled out the holes to 1/64" and used needle nose pliers to put a "factory curl" on the staples. Looks excellent.
For the splash shields, I installed the inner fender to frame seals, after the it was installed, because I wanted to get a good seal. Took me a couple of hours to get all the staples in. (they go from inside to outside) If I had it to do over, I'd install the inner fender and mark the location of the seal. Then pull the inner fender off, to install the staples. Wpuld have taken less time!
I learned about this trick a few years ago on this site or maybe it was the Chevelle site, but none the less, it's a good trick. Take some small gauge wire (for some reason 14guage foral wire comes to mind as what they suggested, but this was a few years ago), close to what the original staple is and cut it to the lenght of a stape. Then install the splash gaurds and use the wire in place of the staples. Just install the wire and bend the ends over. You will find that the wire bends much easier than the staple.
Just a side not, I suppose you could pound the wire flat (well sort of flat, as flat as it will let you) and that will make for a cleaner looking installation.
I have never tried this trick, but it sounds good and much easier than installing those pesky staples. I helped my dad install the staples on his 1968 RS, what a pain that was.
Good luck
Bryan Shook
Favorite Quote - Some people have shrinks. Some people have their garage.
My Father's 1968 RS 327!
My First Generation Camaro site
According to the 69 Factory Assembly Manual, there are three types of clinch for the staples. They are a 37 1/2 degree clinch, a flat clinch and a 45 degree clinch. (Clinch is how the ends are finished) They do not specify which is used where. So, I would guess that you could use any of them but be consistant.
