1 - 18 of 18 Posts
tonight i filled up with a tank of gas and took off down the road. My 67 started to stumble and blow white smoke. I pulled of the road and it intake back fired to a stop. Now it won't start and is blowing white smoke. Is this bad gas, or crap in my carb. Any on else experience this?
1967 rs
edlebrock carb
The smoke is concerning. The fuel doesn't smell like diesel does it? Bad gas will cause a car to die and not start again but I've never seen the problem accompanied by smoke. Also, a timing chain slipping a tooth can exhibit similar problems less the smoke. The car will sputter and die and not start again. When cranked it will back fire through the carb. I'd bring the matter up with the gas station for starters.
-dnult
I was thinking the same thing Diesel (lets hope not). I am sure if the station had gas that was that bad you would have been parked right next to a bunch of other broken down cars. Don't think it can't be diesel, tanker truck could have mixed up the load and put diesel in the unleaded tank. This would explain why you have smoke. Other wise you are burning oil from somewhere.
I thought i put reg 87. I can't remember..... What if it was diesel?
What would it smell like?
Diesel has a distinct smell both burned and unburned. Kerosine is about the closest thing to it. I guess you'd have to whiff some of th vapours to know. But it will be a bit more difficult to tell since the diesel is mixted with gasoline which has a strong oder that would make it a bit harder to detect the diesel.
The good news is that it won't harm your engine, but you would have to drain it all out and fill it with fresh fuel. Draining also would mean purging the line by disconnecting the fuel line near the carb and pumping fuel into a container of some sort. You also would have to remove some fuel from the float bowls. A little diesel in the gas won't hurt though, so you don't have to get every drop out of the system.
-dnult
I am so mad at myself. I wasn't paying attention and filled up with a tank full of diesel. I'm so STUPID.
At least it wasn't a head gasket like I thought
At least you did ruin anything. A little labor and you will be back on the road. Consider it a leson learned. Don't be so hard on yourself, I am willing to bet you will never do that again.
When I was fresh out of high school working at a gas station a customer came in and said "my car was low on water and I filled it up, now it won't run right" he filled it up at the station. Well after I checked the water/coolant it was fine. When I checked the oil guess what I found? Yep, he filled the crankcase with water all the way up to the fill cap. I will never forget that, my jaw dropped to the ground.
These things happen, just learn from it.
In Az, they have green pump handles for the diesel fuel. My neighbor's daughter filled up a chevy truck with diesel. Her excuse was that she usually drives his diesel ford. I thought that the pump nozzles were different so this can't happen ?
So can you retrofit glow plugs and a huffer into your small block and burn the stuff off ? LOL
My dad did the same thing in his motorhome just recently. Put 60 gallons of diesel in a gasoline powered F--d. He made it about a block from the station and it did the same thing yours did.
His only problems were it was on a Sunday, he doesn't know beans about cars or engines, called a tow truck to come get it and take it to a repair service, had to wait until Monday to get the tank drained.
He learned his lesson real quick. (He is 76 years old).
All the gas stations around here use green nozels for diesel except BP and they use green :confused: for gas and black for diesel. Got to watch what your grabbing.
Here in CA the Diesel nozzle is LARGER and it won't fit into the hole on an Unleaded Car. Not sure about a 67-69 camaro though, I believe a Diesel nozzle WOULD fit in this case!
Some commercial (truck stop) diesel pumps have oversized nozzles to aid in filling large tanks more rapidly. Most standard filling stations have normal sized diesel nozzles which will fit any car or truck. Usually they are coded green but some are black. I've even seen yellow pump handles for diesel. You really have to look carefully before you pump! Putting gasoline in a diesel vehicle can be catastrophic unless you are very lucky.
My daily driver VW is diesel powered and I get lots of strange looks from people who see me putting diesel into a car. Sometimes they ask me "do you know that's diesel?" I just smile and say yes! (though I am tempted to act shocked and dismayed)
True here in CA the nozzles are a different size and diesel is usually a green handle. The problem is if you have an older car that was built before the unleaded gas came out, any nozzle will fit. This would include all cars built in the early 70's and before. Newer cars won't accept a diesel nozzle or a regular (leaded nozzle), not that you see those around anymore. I guess working at that gas station was good for something.
umm.. up on the pump, it says what kind of fuel you are getting. common sense dictates that you don't grab a nozzle under a sign that says "Diesel" and expect 87 octane gasoline. also, i've noticed that the diesel pumps tend to be kind of segregated from the rest of them, and the hose is usually a LOT longer. plus, as i already said, it says "DIESEL" on the pump. and the handle tends to be a little more "slimy" from the DIESEL fuel that gets pumped out of it, and has that "DIESEL" smell that just won't go away, no matter how many times you wash your hands or what you wash them with..
not trying to be mean or anything, but, man, if you can't read the gas pumps, should you really be allowed on the road? same with the person that filled their engine with water. that's just stupid, no matter how you look at it.
Novaderrik,
Take it easy man. I am sure you have done a thing or two in the past that you are not so proud of. He just happened to look for help and figured out in a public forum he made a mistake. It's a mistake I promise you he won't make again. I know a while back in the bench racing section there was a thread about "silly" car things people had done in the past. There were some real gems there, so he is not alone in making a mistake. Don't be so harsh, I'm sure he already feels great about it. At least he didn't blame someone else as most people seem to do these days.
Discussion Starter #17
I thought this was a camaro site? Not a white trash, two tone primered, nova site.
1 - 18 of 18 Posts
