Finished Brake kit install except for connecting Master to brake pedal ... questions!
Ok,
I opted for the manual brake kit from right stuff ... everything went very smooth until the last part ...
I can't figure out how to attach the rear of the master to my brake pedal ...
This car was basically a shell when I originally purchased it so some parts are missing ... but I would think that everything that I need is included in the right stuff kit ...
Heres what I have ... I recived a rod extension and a clevis ... I understand that the clevis should bolt or pin in to the upper hole on the brake pedal rod when using manual brakes ... correct? ... where does the brake light switch go --- to the lower hole? ...
Now here's where more of my confussion comes in ... the extension rod to master ... is there supposed to be a piece that connects the master to the extension rod or what ???
Thanks,
TIM
Ok,
Thanks,
TIM
