Any educated guesses or solid confidence on my following combo, 15x8 rim 4-1/2 bs with Hoosier quick time pro drag d.o.t. 26x9.5-15
9.8 sec 26.1 dia. The 69 has multi leafs,factory 12bolt,and factory inner fender,however the quarters were replaced with the foreign half quarters and i dont know if the fender lip is too wide what is the approximate dimension
what about M/T 26x10.0-15 sec.11.0 dia.26
or
M/T 26x10.5-15 sec.10.5 dia.26
thank you
They should work. I have a 69 w/ 5 leaf springs and a 12 bolt with 15x8's with a 4.5 BS on all 4 corners. I have 245/60 Rubber on all 4 corners as well. My overall tire height is 26.55", the section width is 9.47", and a 8" tread width. My fenders are replacements as well. If I had to guess, I would say there is a bout a half inch on both sides of the tire to spare. My "Guess" is that the 26x10.5 with the 10.5 section width would fit, and the 11" will be pushing the limits of the stock fender well.
Shawn Peterson
1969 Z28, 406SB
