1 - 13 of 13 Posts
Just bought a new set of BF Goodrich Radial TA's for my 69 Camaro. Wanted to wait until next year but couldn't. Since this is my first experience storing a car I am concerned with flat spots developing on the tires. Has anyone heard of Flatstopper tire supports? Are they worth the money and do I need them?
BTW I bought my 69 Camaro RS from the classified section on Team Camaro. Couldn't be happier. Developed a great friendship with the former owner to boot!
The tires you have will not flat spot. Don't worry about the flatstoppers NOT needed waste of $. Just make sure the tires are inflated. I'd go 10 psi over for the winter
When I've stored vehicles for long periods I usually put the car on jackstands. When that wasn't possible, I simply rotated the tires 90 degrees every 3-4 months. Never had any issues with flat spots from storage even on a 42,500lbs motorcoach.
I have the same tires and haven't had any issue with flat spotting yet. I used to jack the car up over the winter, but not the past 2 years... without issue. I haven't increased the pressure in them either. Every couple months I roll the car 6 inches forward or back just in case.
if storing on a concrete floor be sure to put a piece of plywood down under the tire...
Concrete's lime does eat at rubber.
Thanks for the feedback. I am interested in everyone opinions as I have much to learn and will most likely be asking for advice on other topics as well. Much appreciated!
Over a winter, I had flat spots on Firestones. Never went away. The car wasn't moved. I would err on the side of caution. Tires are an investment.
My tires on my Jeep used to get flat spots in the winter but, they would go away once the tire warmed up from driving. I don't think those tires were radials, the BFG's I use now don't have that problem.
Discussion Starter #10
This is what BF Goodrich customer support informed me today re flatspots. When storing put a thick piece of cardboard, carpet or a matting down to help prevent flatspots. Bottom line they do not recommend just parking it on concrete. Nontheless I am interested and will give the most weight to the guy's on this forum with experience. Thanks!
Agree 100%
Discussion Starter #12 (Edited)
Thanks for the advice Fred. Looks like your 69 is a lot like mine!
x2 on the jack stands but that is also for rodent control :D
1 - 13 of 13 Posts
