These lines must have come with the kit I bought for my disc brake conversion. As you can see they are very long; to the point they rub on the frame. This one is actually pushing under the bottom of the frame a bit with the steering pretty close to dead center. On the other side it curls up under the A-arm.
These could be three to four inches shorter and still have plenty of reach for the sweep of steering.
And yes, I do notice that I am missing the clip on the frame mount.
DSC_2307 by Larry Madsen, on Flickr
I'm not impressed with them extending out into places they should not be.:(
Is there an easy way (or supplier) to get flex lines of a specific length?
I believe these calipers are early 70s Monte Carlo application.
Take them to All Hose on Post Rd Vegas. Or on N Pecos whichever is closest for you.
They can shorten them for you while you wait.
Discussion Starter #4 (Edited)
Thanks John, Post Road is closer.
I'll give them a call before I pull the lines, but that's exactly what I need ... a place that can make them exactly like I want them ;)
Thanks to you as well Scott. I had wondered about premade, but figured it might be had finding them.
I guess I could ask another question. Is there a good way to determine just how much length is necessary to cover the sweep while keeping the length to a reasonable minimum? Obviously even at full extension we need a bit of slack.
68 Camaro SS/RS clone, 454 BB 4 speed, 3.73 Posi, new paint, motor, trans and diff assembly. 2" Drop
I just went through this when converting to rear disc brakes. I used a length of 12G wire (THHN solid may work better) and ran from fitting and routed to where its supposed to go, then laid it out and measured. Ordered from there.
Pick up the new ends from All Hose. Take them home and cut the old ends off. Shorten the hoses a little at a time using the new ends slipped on to get exactly how you want them. Then take it to All Hose and have them crimp the new ends on the hose.
It's not difficult finding them locally. Just order what you need for the application. I never buy parts from resto vendors when I can buy them cheaper from my local suppliers. Operate your hobby as is if was a business.
Discussion Starter #9
Found a pair premade. I figure my current hoses to be about 16"+ over-all. The ones I found are a bit over 12" over-all.
Comes with a pair of clips, so that problem is solved as well.;)
