I just purchased a new zz4 short block and i would like to no if it is internal or externaly balanced the block has a one peice oil seal so i guess it would be 1986 and newer
all SB except the 400 and a 383 are internaly balanced. the 383 is not a prodution GM SB. it is a bored and stroked 350 useing a 400 crank.
some 383's are internaly balnced, it depend's on the crank.
all 400's are that have a OEM type crank in them are externaly balanced. they make an after market internaly balnced crank for the 400 too.
Well I have the ZZ4 block and the one piece crank and the flex plate has a balance on it due to it not having the flange that the early cranks have.
68 RS, Ash Gold,pwr windows,Hounds tooth,355/T350,Autometer guage pod
that is true, that is too keep the crank balanced, but it is still called an internaly balanced motor. you do not have a extra weight on the harmonic balancer, and the weight you have on the flex plate has less weight then the one on a SB 400.
it is there to make up for the smaller end flange. the larger end flange is part of the balance weight on a old style SB crank.
[This message has been edited by ilbl8 (edited 04-18-2001).]
