I just bought a 1994 Z 28. It is a great car, but there are a few things that need work. One was the exhaust, and the other is my fog lights. I am not sure how to get at them. Can anyone tell me how to get to them without taking the whole front bumper off? Thanks
I've had to put bulbs in one of those. Lucky me, I've only had to do it once. The manual said to take the front bumper cover off. No way, I was only getting 3 tenths of an hour to do the job!!!
You can get to them with out taking the bumper cover off. It's not easy and you loose some skin in the process, but they do come out. Barely! Think I removed some of the screws from under the front, so I could reach up and remove the mounting bolts. And I took them out through the front openings, yes they will fit.
You can use a screwdriver and a pair of needlenose pliers and do it from the front of the car.
Use the screwdriver to pull out the "center" section of the pin...then grab that with the needlenose and pull out to the side.
Get both sides out, and the fog light will pull right out.
Steve - Central Ohio Camaro Club
'69 Camaro RS/SS-350 - Daytona Yellow
'95 Camaro Z-28 - Sebring Silver
click here to see my webpage ---> My Camaros (updated 2/2/02)
