1 - 13 of 13 Posts
Surely somebody has a fix for this. I can only work a few seconds with my goggles or safety glasses on, less time when I wear a mask. Is there anything that I can put on these things to keep them from fogging????
Blinded in Texas....
There is nothing like doing it yourself.
68 Camaro
69 Chevy C/10 swb truck
Yep, there is a product designed for scuba diving that might solve your problem. Most dive shops carry a small bottle of anti-fog liquid for dive masks. Been so long since I was under I forget what brand I used to use, but there are several. You swish it around in the mask/ goggles etc and then pour it out. No fog after that!
Give it a shot! Not too expensive- maybe $5 or so a bottle.
See my '68 RS/ZZ4 at http://www.100megsfree.com/choptop/camaro.html
The makers of rain-ex also have a product
that's called anti-fog or somthing like that
Wal-Mart or auto parts store sell it, it's
made to use on inside of windshield's but
I also use it on safty glasses,goggles and
shield on racing helmet.
Jeff
Motorcycle dealers also will have the stuff. I've used it on my helmets. I suspect and good auto parts store will also have these products.
Rick Dorion
69 RS Conv,355,M20,4.10's and I don't worry about stone chips.
If your safety glasses are the molded one-piece plastic type, you can drill 8 or 9 small (1/16") holes in the area above your nose - this will ventilate them and prevent them from fogging, and the holes are small enough to keep stuff out.
JohnZ
'69 Z28 Fathom Green
68 Base Camaro 355 Offy crossram Richmond Super Street close ratio 5 spd ivy gold 92K SoCal car
You'll find it at good athletic supply stores too, hockey players use it up here on their plexiglas visors. They do make goggles that have vents built into them to help them breath and prevent fogging. But if you're in the gulf area of Texas good luck. My experience working down there is it's so humid almost any goggle or shield will fog over.
Dave
Discussion Starter · #10 ·
I have regular goggles with the vents, they fog without and with a mask. I have safety glasses with the foldout side gaurds also vented, they fog with a without a mask. I have the one piece safety glasses non vented, they fog with and without a mask. I really would like to continue using a mask due to all the welding, grinding and sanding I am doing. Thanks for all the help guys, I will be picking up some stuff today. I just have to finish my driver side floor and I'll be ready to bolt her back up.
68 Camaro
Discussion Starter · #13 ·
Your twisted Danny....
68 Camaro
<A HREF="http://
http://hobbystage.net/camaro/waynes68" TARGET=_blank>
http://hobbystage.net/camaro/waynes68</A>
1 - 13 of 13 Posts
