The frame mounts I purchased have a L and a R
stamped on them. I tried putting them on with the L being the drivers side and the R being the passanger side. They just don`t look right that way, they look better the opposite.
which way is correct?
Discussion Starter · #5 ·
I changed my mounts back so left was drivers side and the engine mounted just fine, It sure didn`t look correct but it is. now for the firewall massage to fit the distributor.
When the frame mounts are on right - they look wrong. The key is realizing that they MUST hang over the frame by about 1". If you put them on backwards your driveshaft will come up about 2" too short, the tranny mount won't line up, and your headers won't fit.
68 Camaro, 383 small block with TH350 trans. 11.98's at 111mph and never trailered.
