It offsets the engine to the pass side appx an 1/2 inch and forward about an inch, it is room you need for exaust to steering box clearence and firewall also. You can use the smallblock mounts, but you will have to grind or dimple the exaust for clearence.
69 rallye green X77 Z/28,1967 SS 396 Conv. 1974 c-10 454 swb
Discussion Starter · #4 ·
The other problem i am having is wipermotor i had tall valve covers to clear my rockers now i cant clear wiper motorunless i run shorter valve covers i dont want to change my rockers am i stuck with one or the other just wondering
You also need a bb transmission crossmember, z-bar and a few other bits.
67s had a unique wiper motor with a round base. 68-69 used a motor with a rectangular base. The 68-69 mounting was rotated about 90º CCW for rocker cover clearance. Not much you can do for clearance on your '67 short of removing it.
