I am likely needing to replace at least one frame rail due to a small crack from some rearend mishap and a bend due to someone bottoming out the diff into it...must have been a Duke's of Hazard type of moves. I also have to replace a shock tower and rusted wheel housings. Can this be done on a rotisserie? Which should I do first, the rail or shock tower ?
Hi David..
I'd think you'll need to:
- pull the frame-rail section
- replace the shock-tower
- verify the car is level / square & brace it.
- then replace frame-rail section
..and it depends on the rotisserie..
Mine attaches to the bumper mounts, which relies on the frame-rail for structural support.
Other rotisseries I've seen attach to the shackle support, also on hte rear frame-rail.
..so no to those kinds of rotisseries.
If you have a rotisserie that clamps onto the body, possibly..
If you want to do it yourself, I suggest making a jig, or renting a wheel lift.
The kind you drive onto, not the type that lifts the body.
That way you can take measurements from a baseline, and use bottle jacks or screw jacks where necessary.
You'll also want to drop the fuel tank, rear-axle, brake lines, rear-seat, ect.
or take it over to
Bear Frame & Axle (Broadway & Hampden)..
ask for Matt. (tell him I sent you..)
He is very good.. ..and may work you a deal.
Good luck..! :thumbsup:
