I have a 68 Camaro convertible, 327 4-speed. I need the front frame specifications to check if my frame is bent. Any help would be appreciated. Thanks,
RAGTOP68
I'm not sure if you'll be able to find any documentation that shows such measurements... If you have anything specific you need I'd be happy to take some measurements (but my subframe is off the car). If it is the subframe then you can get a used replacement without spending too much... What makes you think your frame may be bent?
Matt
http://camarotech1.com
Camaro Tech 1st Generation
What do you mean by frame specs? There are the datum line specs in the body book, the only difference being the frame rail specs over the axle is taller in the convertible.
It also has the front end specs so you can 'X' it out and the sub frame specs.
67 Camaro SS Conv.
70 Challenger R/T Conv.
