Hi,
I am close to order front disc brake kit http://www.classicindustries.com/camaro/parts/rs900101.html.
I have a few things I would like to straiten out before I order.
My -67 Camaro has manual drums brakes.
* Is the kit complete or is there anything else I need to order (I will build the hardlines by myself)?
* What sixe has the power booster?
* Are all needed valves (proportion, metering etc) included?
Rgds/Mikael
Hi,
Rgds/Mikael
Mikael, that looks like a complete kit. 11" booster. All you should need is the bearing grease, brake fluid and hard lines with fittings to go to the front brakes. You might also need to a new hard line going to the back brakes as the location of the distribution valve will wind up in a slightly different location
Joe,
A bit late, but thanks for your reply. I have found a supplier in Sweden (where I live) to buy from which makes it a bit easier if something fails...
Rgds/Mikael
