After replacing the front coil spring in my 69 coupe the steering wheel is no longer centered. Would this be common for a car after coil replacement?
No. it would not be common. Unless you adjusted the tie rods etc, the centering of your steering wheel, would not change.
If the ride height changed, the caster and camber changed. I always had to set the toe in after changing the caster and camber. The toe could change the centering of the wheel.
Jeff
Should I wait untill I change out the rear springs & shocks before having the front end aligned or does it not matter?
