Both of my front subframe aft attachment points are rotted and wallowed out. Will a subframe connector kit cover the affected area, or is there another fix other than replacing the subframe, or welding in a patch peice?
Not that I am aware of. See the related post in Camaro tech.
Thats a common problem area. The rubber bushing holds water inbetween it and the frame and causes the rot. More of them are rotted there then not. They sell a kit to repair this but it might not cover all the area that you need. I would use 1/16" plate and fab up the area and use the correct sized holesaw to make the hole for the body mount.
Thanks for the posts, a yes the other areas have rot too. $1600 not including shipping for a new subframe eats into my engine rebuild and over drive tranny dreams thou. I have not found any repair kits, and I'm concerned that fab'in up a repair may cause hole misalignment, and that may cause other issues down the road.
There a couple subs for sale on ebay right now. $750 and $450. Another couple hundred and you could have them powdercoated at a nearby shop.
You can have a good welder patch that but like other's have said, being that bad I would worry about the rest of the frame's strength. If that's a TX car it must have been from near the coast.
