I want polyurethane bushings instead of buying the whole kit from energy suspension wich is almost $200...can i just put poly on control arms? And maybe the tie rod end boots and ball joint boots? Ima buy ball joints and inner and outer tie rods .. And ill get the hotchkis sway bar wich i believe has the polyurethane kit to install????
Control arms, sway bar bushings and end links, and upper and lower control arm bumpers is about it for the front until you get to sub-frame bushings.
The black ones are quieter then the red from what I understand
John, I have never heard that very interesting. I use black to not stand out. I got the kit. Energy has a nice kit. I used Moog ball joint caps , the poly ones are very shiny. Just my opinion.
As I understand it the black have graphite in the poly and the red does not.
