I have a 350 / 300 hp: When I bought the car, the vapor line was plugged and used only one fuel line from pump to carb. I am wanting to go back to the original type with the (3) lines and canister filter. For you guys that stay up on the original style, does the 350 engine use a bracket to hold the filter? Most parts houses show only a bracket for the 396cu engine. The Assembly manual does not show one on the 350cu engine whereas the 396cu shows the bracket. Also where do you find the clips that hold the line together.
