I decide to go for a cruise tonight. I turn on the headlights/dash lights and only the fuel gauge is lit. I mess with the knob, etc and nothing. I go on the drive anyway. About two miles down the road the speedometer light comes on! What is a common culprit here? When I got home I turned off the switch and back on again..and it worked. Short?
I would check the ground on the gauge cluster first. if that don't work then try another switch
this is just my opinion only!
x2 Loose ground wire at dash connection and or a loose bulb in the speedo pod or broken filament in that bulb that reconnected as you hit a bump or something in the road. I assume the heater light was working as well?
Actually I don't remember if heater light was on or not. I'll look in there today. Where would I find the ground wire for speedometer? Black I assume, coming from speedometer?
