Fuel guage / sender troubleshooting
7922 Views 4 Replies 4 Participants Last post by  jlphillips
sorry guys
This has now been added to the "electrical Basics" sticky
I want to add that sender problems are sometimes due to bad contacts within the sender even when NEW. You can fix them by modifying the sender.
I had a series of brand new sender units that didn't work. There are two problems that can occur together. The connection from the resistor assembly (specifically the ribbon-shaped connector) to the outside pin was poor/nonexistent. The push-on connector is supposed to maintain contact (continuity) between the internal metal ribbon, and the "inside" end of the pin (which connects to the gauge wire on the outside). Neither the ribbon, push-on clip, or pin should touch the tank metal, or the sender body.
So the problems are:
1. The ribbon-connector may be rotated such that it touches the top of the tank causing grounding AFTER installation.
2. The push-on connection is open or opens up due to problem 1.
The photos below show how to modify the inside-to-outside pin, making a more stable junction to the ribbon connector. Pictures A & B show the push-on clip connection, and how to rotate the ribbon connector away from the edge of the sender, to avoid hitting the tank after installation. In picture C, I removed the push-on clip by grinding off a few "tangs" with the rotary tool. Then pull the pin out, and clamp the "outside" end in a vice. Put 6NB-32 threads on the "inside" (gasoline-side) portion of the pin. The last picture (D) shows the pin re-installed using a brass nut in place of the push-on clip. The resistance after modification was 0.9 Ohms at empty, and 89.1 Ohms at full.
See less See more
had problems with my temp. gauge and later my fuel gauge--69 z-28 console gauges--read your helpful link at chevelles.com on how to trouble shoot fuel gauge problems--to make a long story short, i had a ground problem in console.i had replaced fuel sending unit before i had enough sense to check first--when installing the sender, i had bent the insulated link at sender against the pickup tube,therefore grounding it out.after pulling my hair out, i printed off your trouble shooting guide and started over. great information . i am very greatful that you took the time to post this. thanks again--jflops
