Keep getting fuel in the oil pan, I did a rebuild of the car,seems ok if i take the plugs out clean them seems ok. could the carb not handal the fuel regulator set at 6.5 psi with holley blue the carb is a holley 4010 750 what to do..... what els should I check and is the cylinders washed know?
Sounds like a ruptured fuel pump diaphram
If the fuel pump diaphram is intact, then I would think the fuel is coming down the cylinder walls. Is the car hard to start, or prone to flooding ... RUnnning really rich? ... If so, I would re-visit the carb, check the floats, and make sure that the fuel pressure is not too high ... might try going back to 6 psi ...
thats what I am thinking that the carb is not set right, if i let it sit for a few days then start it its great,I just picked up a 850 DP do you think that may to munch for a 406, the desk top dyno said it should have a 900+ what do you think.
406 roller
492 heads hevy ported
cam 300AR 264-266 at.50 with a 630 lift
victor Jr intake
msd distributor billet pro
accel 300+ ignition
carbs that I have (4010-is a 750 need work flooding engine),650DP,850DP
400 trans with tci trans brake
12 bolt with 3: 08 and 5:14
From what you list, it doesn't seem that the 850 would be overkill ... Still, expect to have to do some carb tuning ... That will probably fall under the category of try and try again ... Afterwards, I suspect this thing will pin you to the back of your seat and make your eyes open wide! ... ought to be a blast to drive ...
