Discussion Starter · #5 ·
the reason i asked about converting is most of the wires have been cut to all the sensors. Motor has ben changed from a 1988 to a 1992, wiring harnesses r different. It runs but without th sensors will it burn up the motor? Does anyone have another solution to this other than to convert from fuel injected TB to carborated.
why not just get the proper wiring harness from a donor car in the boneyard?
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see pics here http://community.webshots.com/user/novaderrik
TBs are pretty simple and don't have a lot of sensors. At that age, it should be reasonable to get what you need from a junk yard
69 convertible
LT1 4L60E
