1 - 2 of 2 Posts
I have a 68 coupe with a mild 350/th350 and am wanting to convert to EFI/overdrive. I am not looking for a 500hp monster (not that is a bad thing), just something that will get some respect on the street. I know that several of you on this board have done this and I need some advice. I am stuck trying to decide between a modern LT1/4l60e or using my current set up with a edelbrock pro-flo/200r4 system. I talked to the bowtieoverdrive company and they gave me some good info for going the 200r4 route, but it will cost about $1500 after everything is said and done and still put another $2000 into the edelbrock/holley mpfi system. I have a chance to buy an 95 impala ss eng/tranny for about $1500. I have an idea about the fuel system conversion and understand that I would have to convert the current lt1 harness or get a stand alone wiring system for it (have researched the conversion process). I would like any advice from anyone that has converted (to either one).
Thanks,
130fe
Your local emission jurisdiction should be also considered when doing the swap, so it can be recertified back on the road.
a)Lt-1 motors are reversed flow, check on the radiator for the swap.
b)You need to get a new speedometer to match the Lt1 tranny.(keep the Vss)
c)Shorten driveshaft and new yoke to match new Lt-1 tranny, need new Tranny support
d)Accesories location have to be considered
and pcm location.
1 - 2 of 2 Posts
