1 - 2 of 2 Posts
Guys
I am alittle confused about the fuel line set-up on the 396 in my pace car. It has the main and return lines to the tank. It has an inlet and outlet on the fuel pump and also a return outlet.The fuel filter also has the same set-up.Does anyone have diagram on how the lines are ran?? From where and to where. Also,where does the fuel filter mount at?? Does anyone have some good pictures of a 396??
Thanks,David :confused:
Sounds like you have the wrong fuel pump. Fuel pump should have 1 3/8 tube for a hose and a threaded block for a 3/8 steel line. The return line goes from the fuel filter back to the tank.
1 - 2 of 2 Posts
