I have a 80 camaro with a 350. I have a 600cfm edelbrock carb i also have a summit dis on it too. The problem is the car lacks the power that it should have. It will not go to far over 2000 rpms I am not sure if i have a vacume leak or not. I have just had the timeing set and the valves set. It still dies when warms and i try to hit the gas. It is almost like it is not getting enough fuel but filter is new. Not sure what to do PLEASE HELP thanks
My 2 cents worth, Check fuel pump pressure, all filters and it's possible the screen in the gas tank could be clogged.
