Qeustions:
1. can a deadhead style regulator be used as a bypass regulator by routing the supply line to the side(originally to carb bowl), and the return from the bottom (original supply inot regulator)? Or is a dedicated bypass regulator required?
2. when using a bypass style fuel system is it MANDATORY to use a return line larger than the supply? Or can the return be EQUAL size, or how much smaller can you go??
