You need to measure the solid fuel line coming from your tank to find what size you have. While ypur in there check for a return line. What does your gauge do if you ground the brn sending wire?
My guage went to empty when I grounded the brn wire coming from the guage.You need to measure the solid fuel line coming from your tank to find what size you have. While ypur in there check for a return line. What does your gauge do if you ground the brn sending wire?
I don't know how much gas is in the tank. Last year I just filled it up every couple times out just so I wouldn't run out. So at this point I don't know. How long of a process is it to drop the tank? And any special instructions I should know? Spring is almost here and I want to be up and running soon.I think your correct about the sender sounds like its bad or just stuck on full. How much gas do you have in the tank? I think at this point you need to drop the tank. You can bench test the sender once its out of the tank too. If your one of those guys with an unlimited budget you could just order the sender. I went through pretty much the same thing but my sender was stuck on full once I cleaned it up I was able to get a positive bench test and just reused the sender. Its still working to this day.
Nice one Jim!:thumbsup: Got the tank out after syphoning some gas out so not to drop it to hard. Cleaned up the unit and bench tested it and finally got some resistance readings. Now I have to wait to get a new tank strainer before I reinstall it as the old one was torn. The bad news though was that I didn't find a build sheet either, darn. Thanks again for all the help that I've obtained from this site. It's been great for someone such as I - a novice! :bow: :bow:How hard it is to drop the tank depends on how much gas is in there!!![]()
undo the fuel line, remove the screw for the ground wire, push the sender wire and grommet thru the hole in the trunk, then take the nuts off at the back of the straps and it will basically fall out. How hard it falls, of course, depends, see above.
